Dreammultimedia Digital-RX DM 500 s
Reparaturtipps und Ersatzteile zum Fehler: Box dont work
Serverzeit: 18 11 2026  02:13:40      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digital-RX Dreammultimedia DM 500 s --- Box dont work
BID = 671186
metropar
Defekt : Box dont work
Hersteller : Dreammultimedia
Gerätetyp : DM 500 s
Hi
have a dreambox 500 that wont work
netzteil new oke
put in new bootloader :oke
with dreamup i cant nomali flash the box and its going normal
no problem. when done dreamup tell flash box write oke
bad when restart box box dont work noting on tv
i have make backup with dreamup from flash en read out with hex conv.
image was write into flash ok .i have compare with orig.image and its
seems to be oke
bad still nothing on tv ?
gr metropar
BID = 671408
Satfan123
Sat- und DBox-Spezialist
looks like a defective processor
BID = 671642
metropar
How to find out if the proc. its the problem
Try to log with hyperterm.?
Gr metropar
BID = 672319
Satfan123
take the Oszilloscope and then you can see what is defective
BID = 672679
metropar
Well the proc its oke nothing wrong with the proc
I have put in other image pl.
And now i have some pict on tv bad the pict. do not sychroon
So i think its tuner probl
Maybe the output of tuner to week
gr metropar
BID = 673160
Satfan123
this is often not the tuner circuit :D:D
© x sparkkelsputz        Besucher : 194331418   Heute : 970    Gestern : 12669    Online : 997        18.11.2026    2:13
